Salta al contenuto principale
Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement
Cosa ti serve
  1. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: passo 1, immagine 1 di 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: passo 1, immagine 2 di 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: passo 1, immagine 3 di 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo.
  2. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 2, immagine 1 di 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 2, immagine 2 di 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 2, immagine 3 di 3
    • Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 3, immagine 1 di 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 3, immagine 2 di 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 3, immagine 3 di 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 4, immagine 1 di 1
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 5, immagine 1 di 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 5, immagine 2 di 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 5, immagine 3 di 3
    • Remove the silver divider
    • Remove black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 6, immagine 1 di 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 6, immagine 2 di 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 6, immagine 3 di 3
    • Remove the ribbon cable from the slot on the LED/speaker board
  7. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 7, immagine 1 di 1
    • Remove the LED/speaker board
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team S1-G3, Leahy Fall 2017 Membro di USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Membri
12 Guide realizzate
1Commento della guida
I can’t seem to find the board anywhere. Where would you buy one?
George hanes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 29
Tutti i Tempi: 5,574
