Salta al contenuto principale
Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement
Cosa ti serve
  1. Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement, 4-in-1 WiFi/Bluetooth/FM/GPS: passo 1, immagine 1 di 3 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement, 4-in-1 WiFi/Bluetooth/FM/GPS: passo 1, immagine 2 di 3 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement, 4-in-1 WiFi/Bluetooth/FM/GPS: passo 1, immagine 3 di 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 2, immagine 1 di 3 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 2, immagine 2 di 3 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 2, immagine 3 di 3
    • Use a T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 3, immagine 1 di 3 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 3, immagine 2 di 3 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 3, immagine 3 di 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 4, immagine 1 di 1
    • Remove the motherboard
Conclusione
Altre 7 persone hanno completato questa guida.
Alexis White
Membro da: 10/09/17
505 Reputazione
2 Guide realizzate
USF Tampa, Team S1-G3, Leahy Fall 2017 Membro di USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Membri
12 Guide realizzate
2 Commenti
Where can I find the part my dot won’t connect and I have been going crazy trying to find the motherboard
Ivy Bowman - Replica
I wish to recommend not removing the adhesive layer if you plan to reassemble this Echo Dot. I would suggest poking holes to reach the four screws instead. Then reassembly can reuse the same adhesive layer.
rayramirez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 30
Tutti i Tempi: 6,288
