Salta al contenuto principale
Amazon Echo 2nd Generation AMP Board Replacement
Cosa ti serve
  1. Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: passo 1, immagine 1 di 3 Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: passo 1, immagine 2 di 3 Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: passo 1, immagine 3 di 3
    • Remove the rubber layer beneath the device.
    • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
    • Remove the four 8.0 mm T8 Torx screws on the lid.
    • Remove the lid from the device.
  2. Amazon Echo 2nd Generation AMP Board Replacement: passo 2, immagine 1 di 3 Amazon Echo 2nd Generation AMP Board Replacement: passo 2, immagine 2 di 3 Amazon Echo 2nd Generation AMP Board Replacement: passo 2, immagine 3 di 3
    • Use a spudger to flip up the small flap on the ZIF connector.
    • Gently pull the ribbon cable out of the ZIF connector.
    • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
  3. Amazon Echo 2nd Generation AMP Board Replacement: passo 3, immagine 1 di 2 Amazon Echo 2nd Generation AMP Board Replacement: passo 3, immagine 2 di 2
    • Use a spudger to lift up one of the small flaps on only one side of the female connector.
    • Pull on the wire toward the lifted side until the male connector is disconnected.
    • Remove the AMP Board.
Conclusione
Altre 4 persone hanno completato questa guida.
Eric Inman
Membro da: 10/08/18
337 Reputazione
3 Guide realizzate
Cal Poly, Team S4-G4, White Fall 2018 Membro di Cal Poly, Team S4-G4, White Fall 2018
CPSU-WHITE-F18S4G4
3 Membri
5 Guide realizzate
4Commenti sulla guida
Can anyone find a replacement board?
Tristan Parks - Replica
I need a ramp board for echo show second edition.if its too much ill just scrap it you know.I'm just board and tinkering with it.my friend plugged wrong amount of juice into it and fried this board I imagine because it was working fine before that
Alex Cross - Replica
Is it possible to get a replacement ribbon cable for this model?
Gerry Tweedie - Replica
I have a need of one such a bord
Attmaram Nagorao Sugandhe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 40
Tutti i Tempi: 4,422
