Introduzione
Here is an Amana washer that had issues with the motor. This was determined after running the automatic diagnostics. Replacement is straight forward with no pitfalls or difficulties.
To work on this replacement, you will need to gain access to the bottom. It is best to place the washer on its front. Place a few old blankets etc. so as not to scratch the front to much. Since I did a total rebuild on this washer, I had also removed the control panel. It was easier for me to place the washer upside down :-)
Cosa ti serve
First the pulley cover has to be removed. It is attached via two 5/16 bolts
Use an electric screwdriver with a short extension and a 5/16 socket to remove the right screw,
followed by the left screw, is easiest. A hand ratchet or a nut driver will of course work as well.
Remove the pulley cover
Now clearly visible are motor, pulley for the drive (clutch/splutch is underneath), shift actuator and start capacitor for the motor
To remove the drive belt, lift one side up and then pulling it to the drive pulley while continuing to pull up on it. The belt will eventually run off the pulley
Altre 4 persone hanno completato questa guida.
