Introduzione
Even so we know this as a clutch assembly on other washers, "Splutch" is a term used for the Whirlpool washing machines. It refers to the cam assembly kit (or splutch kit). This assembly is a main component of the transmission system. It can wear out over time and running heavy loads with a full tub of water can shorten the lifetime of a splutch. Poor wash performance as well as grinding noises while washing, are a sign of a worn splutch.
Cosa ti serve
To work on this replacement, you will need to gain access to the bottom. It is best to place the washer on its front. Place a few old blankets etc. so as not to scratch the front to much. Since I did a total rebuild on this washer, I had also removed the control panel. It was easier for me to place the washer upside down :-)
First the pulley cover has to be removed. It is attached via two 5/16 bolts
Use an electric screwdriver with a short extension and a 5/16 socket to remove the right screw,
The pulley is held in place by a 13mm nut
Using a ratchet and socket to remove it.
Since the pulley will easily turn when using the ratchet, it is best to tap the ratchet handle by hand instead of trying a continues motion. It is common thread (Lefty Loosey). Of course, an impact wrench would be simpler :-)
The nut does come of fairly easy once it is loose.
Remove the drive pulley from the shaft. Next is the drive basket gear.
The drive basket gear sits on a spline on the drive shaft. Check the spline on the basket drive shaft if the teeth on the basket gear show damage.
There are four tabs that hold the splatch housing to the gearcase
Altre 2 persone hanno completato questa guida.
