Salta al contenuto principale
Amana NGD4655EW1 Dryer Door Handle Replacement
Cosa ti serve
  1. Amana NGD4655EW1 Dryer Door Handle Replacement, Door Handle: passo 1, immagine 1 di 2 Amana NGD4655EW1 Dryer Door Handle Replacement, Door Handle: passo 1, immagine 2 di 2
    • Clean the area around the door handle with a cloth.
  2. Amana NGD4655EW1 Dryer Door Handle Replacement: passo 2, immagine 1 di 1
    • Position the door handle replacement where it suits you best.
    • Use a level to make sure the door handle is straight and neat.
  3. Amana NGD4655EW1 Dryer Door Handle Replacement: passo 3, immagine 1 di 2 Amana NGD4655EW1 Dryer Door Handle Replacement: passo 3, immagine 2 di 2
    • Use a marker to mark where the four screws are going to be placed.
  4. Amana NGD4655EW1 Dryer Door Handle Replacement: passo 4, immagine 1 di 2 Amana NGD4655EW1 Dryer Door Handle Replacement: passo 4, immagine 2 di 2
    • Place the point of a center punch in the middle of a mark.
    • Take a rubber mallet and lightly hit the top of the center punch to make an indentation in the dryer door.
    • Repeat this process for the other three marks.
  5. Amana NGD4655EW1 Dryer Door Handle Replacement: passo 5, immagine 1 di 2 Amana NGD4655EW1 Dryer Door Handle Replacement: passo 5, immagine 2 di 2
    • Use a 1/4" nut driver to drive the Tek screws into the four indentations.
    • Be sure to sweep up and dispose of any metal shavings before moving on.
  6. Amana NGD4655EW1 Dryer Door Handle Replacement: passo 6, immagine 1 di 3 Amana NGD4655EW1 Dryer Door Handle Replacement: passo 6, immagine 2 di 3 Amana NGD4655EW1 Dryer Door Handle Replacement: passo 6, immagine 3 di 3
    • Line up the holes in your new handle with the holes in the dryer door.
    • Screw the Tek screws in the holes previously made, securing the handle into the dryer door.
Conclusione
You should now have a fully functional door handle for your Amana dryer machine!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 32
Tutti i Tempi: 630
