Salta al contenuto principale
Aluratek ADMPF310F Motherboard Replacement
Cosa ti serve
  1. Aluratek ADMPF310F Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 Aluratek ADMPF310F Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 Aluratek ADMPF310F Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Using the black nylon spudger, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Motherboard Replacement: passo 2, immagine 1 di 1
    • Lift screen out of place so you can access the plugs that connect it.
  3. Aluratek ADMPF310F Motherboard Replacement: passo 3, immagine 1 di 2 Aluratek ADMPF310F Motherboard Replacement: passo 3, immagine 2 di 2
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the mother board.
    • Be careful as this zif connector is very frail plastic.
  4. Aluratek ADMPF310F Motherboard Replacement: passo 4, immagine 1 di 1
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Motherboard Replacement: passo 5, immagine 1 di 1
    • Pull out remote receiver out of its clip.
    • Be careful to not move the wires around for the remote receiver too much, as they are soldered to the motherboard.
  6. Aluratek ADMPF310F Motherboard Replacement: passo 6, immagine 1 di 2 Aluratek ADMPF310F Motherboard Replacement: passo 6, immagine 2 di 2
    • Using fingers pull the first speaker wire that is located closest to the speakers
    • Again using your fingers, pull out the second speaker wire near the far side of the motherboard.
  7. Aluratek ADMPF310F Motherboard Replacement: passo 7, immagine 1 di 3 Aluratek ADMPF310F Motherboard Replacement: passo 7, immagine 2 di 3 Aluratek ADMPF310F Motherboard Replacement: passo 7, immagine 3 di 3
    • Using the ph0 phillips head screwdriver unscrew the four 4mm screws circled in the picture.
  8. Aluratek ADMPF310F Motherboard Replacement: passo 8, immagine 1 di 1
    • Pull up the smaller end of the motherboard.
    • Apply force pulling away from the USB ports to get the mother board out of place.
Conclusione
Pascal Alexis
Membro da: 11/05/15
427 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 5-1, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 567
