Salta al contenuto principale
Alternative Opening Procedure
Cosa ti serve
  1. Alternative Opening Procedure, Alternative Opening Procedure: passo 1, immagine 1 di 1
    • Instead of a putty knife a dozen or more 1-1/2" pins are required.
  2. Alternative Opening Procedure: passo 2, immagine 1 di 2 Alternative Opening Procedure: passo 2, immagine 2 di 2
    • With the computer upside down identify the apertures where the catches are located along either side and also at the front.
    • Insert the pins from the adjacent apertures between the wall and each catch. Be very careful to keep the pins against the case wall. This is more obvious from the second photo with the case removed.
  3. Alternative Opening Procedure: passo 3, immagine 1 di 1
    • Lift the case off from the back first.
    • Remove the pins from the main assembly.
Conclusione
Re-assembly does not require the pins. Place the case over the computer and press down evenly on the sides, not the middle. Ensure the back panel is correctly aligned before finally pushing home the catches.
Altre 16 persone hanno completato questa guida.
Donald Todd
Membro da: 09/22/10
528 Reputazione
1 Guida realizzata
Un commento
I've recently acquired a G4 Mini 1.33 "Silent Upgrade" on eBay and plan on opening up using your guide :) Thanks so very, VERY much!
Tyler Regas - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 15,020
