Introduzione
If you are having issues with sound quality, this guide will show you how to remove the two speakers found within your device.
Cosa ti serve
Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
Use a lever motion, push the tool down, lifting the speaker face.
Use fingers to grip and remove speaker face.
Repeat on reverse side to remove the second speaker face.
Detach the two wire connections from the motherboard.
Remove the speaker bed from the internal cavity of the device.
