Salta al contenuto principale
Altec Lansing VersA Smart Speaker Head Replacement
Cosa ti serve
  1. Altec Lansing VersA Smart Speaker Head Replacement, External Panels: passo 1, immagine 1 di 1
    • Remove external rubber cover.
  2. Altec Lansing VersA Smart Speaker Head Replacement: passo 2, immagine 1 di 2 Altec Lansing VersA Smart Speaker Head Replacement: passo 2, immagine 2 di 2
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Altec Lansing VersA Smart Speaker Head Replacement: passo 3, immagine 1 di 2 Altec Lansing VersA Smart Speaker Head Replacement: passo 3, immagine 2 di 2
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Altec Lansing VersA Smart Speaker Head Replacement: passo 4, immagine 1 di 1
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
  5. Altec Lansing VersA Smart Speaker Head Replacement, Speaker Head: passo 5, immagine 1 di 3 Altec Lansing VersA Smart Speaker Head Replacement, Speaker Head: passo 5, immagine 2 di 3 Altec Lansing VersA Smart Speaker Head Replacement, Speaker Head: passo 5, immagine 3 di 3
    • Detach the two wire connections from the motherboard.
    • Remove the speaker bed from the internal cavity of the device.
  6. Altec Lansing VersA Smart Speaker Head Replacement: passo 6, immagine 1 di 2 Altec Lansing VersA Smart Speaker Head Replacement: passo 6, immagine 2 di 2
    • Orient speaker bed so the speaker heads are facing up.
    • Remove the two 14mm screws using the Phillips #1 screwdriver.
  7. Altec Lansing VersA Smart Speaker Head Replacement: passo 7, immagine 1 di 2 Altec Lansing VersA Smart Speaker Head Replacement: passo 7, immagine 2 di 2
    • Separate the two plastic pieces of the speaker bed.
    • Flip the top plastic piece so the speaker heads are face down.
    • Speaker heads may fall out on their own.
    • Remove the two speaker heads.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 512
