Salta al contenuto principale
Altec Lansing VersA Smart Motherboard Replacement
Cosa ti serve
  1. Altec Lansing VersA Smart Motherboard Replacement, External Panels: passo 1, immagine 1 di 1
    • Remove external rubber cover.
  2. Altec Lansing VersA Smart Motherboard Replacement: passo 2, immagine 1 di 2 Altec Lansing VersA Smart Motherboard Replacement: passo 2, immagine 2 di 2
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Altec Lansing VersA Smart Motherboard Replacement: passo 3, immagine 1 di 2 Altec Lansing VersA Smart Motherboard Replacement: passo 3, immagine 2 di 2
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Altec Lansing VersA Smart Motherboard Replacement: passo 4, immagine 1 di 1
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
  5. Altec Lansing VersA Smart Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove the five wiring attachments (for the volume board, bluetooth board, speakers, and microUSB) from their connection to the motherboard by pulling slightly.
  6. Altec Lansing VersA Smart Motherboard Replacement: passo 6, immagine 1 di 2 Altec Lansing VersA Smart Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove the two 9mm screws holding the motherboard in place using the Torx T5 screwdriver.
  7. Altec Lansing VersA Smart Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the motherboard.
Conclusione
Un commento
Where can you buy replacement PCBS for ALTEC products?
Kelly Raile - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 13
Tutti i Tempi: 352
