Salta al contenuto principale
Altec Lansing Mini Lifejacket 2 Speaker Replacement
Cosa ti serve
  1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: passo 1, immagine 1 di 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: passo 1, immagine 2 di 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: passo 1, immagine 3 di 3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 2, immagine 1 di 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 2, immagine 2 di 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 2, immagine 3 di 3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 3, immagine 1 di 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 3, immagine 2 di 2
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 4, immagine 1 di 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 4, immagine 2 di 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 4, immagine 3 di 3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 5, immagine 1 di 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 5, immagine 2 di 2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 6, immagine 1 di 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 6, immagine 2 di 2
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 7, immagine 1 di 1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 8, immagine 1 di 1
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 9, immagine 1 di 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 9, immagine 2 di 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 9, immagine 3 di 3
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: passo 10, immagine 1 di 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: passo 10, immagine 2 di 2
    • Remove the three 9.3 mm Phillips #1 screws on the speaker cover.
  11. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 11, immagine 1 di 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 11, immagine 2 di 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 11, immagine 3 di 3
    • To remove the speaker, gently pull out the its wire harness.
  12. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 12, immagine 1 di 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 12, immagine 2 di 2
    • Remove the rubber ring from the rim of the speaker.
    • This ring helps keep water from entering the device. Be careful to position it correctly during reassembly.
Conclusione
Stephen Albrecht
Membro da: 02/14/18
1.029 Reputazione
4 Guide realizzate
USF Tampa, Team S3-G2, Nance Spring 2018 Membro di USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Membri
4 Guide realizzate
2 Commenti
What speaker should we be getting to replace the faulty speaker, including the wires needed to plug into the slots on the board?
russell rogge - Replica
Where can I get this speaker parts?
T Rex movies - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 31
Tutti i Tempi: 4,016
