Salta al contenuto principale
Introduzione
If the battery in your Altec Lansing Mini Lifejacket 2 isn't holding a charge or is showing signs of failure, use this guide to replace it.
  1. Use the spudger to remove the eight black pins from the front and back of the wire screens. Use the spudger to remove the eight black pins from the front and back of the wire screens. Use the spudger to remove the eight black pins from the front and back of the wire screens.
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger. Removing the secondary pins from the rubber casing is optional. Removing the secondary pins from the rubber casing is optional.
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Remove both black and orange layers from the speaker body. Remove both black and orange layers from the speaker body.
    • Remove both black and orange layers from the speaker body.
  4. Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device. Slide the mounting plate out to remove it. Slide the mounting plate out to remove it.
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Pry off the wire mesh on both sides using a metal spudger. Be gentle to avoid bending the mesh.
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Using tweezers, remove the four rubber stoppers in each corner of the rear panel. Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Pull the case apart to access the interior components.
    • Pull the case apart to access the interior components.
  9. To remove the back panel, gently pull out its wire harness. To remove the back panel, gently pull out its wire harness. To remove the back panel, gently pull out its wire harness.
    • To remove the back panel, gently pull out its wire harness.
  10. Disconnect the battery from the motherboard. The battery is not secured within the case and can be removed after detaching its wiring from the circuit board. The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
    • Disconnect the battery from the motherboard.
    • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
Conclusione
Stephen Albrecht
Membro da: 14/02/2018
730 Reputazione
4 Guide realizzate
USF Tampa, Team S3-G2, Nance Spring 2018 Membro di USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Membri
4 Guide realizzate
Where can you get the batteries? Altec Lansing doesn’t carry them.
alanp5 - Replica
Search for MCR18650 battery. They are available.
F Hickisch - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 102
Ultimi 30 Giorni: 421
Tutti i Tempi: 5,047
