Salta al contenuto principale
Altec Lansing BoomJacket Speaker Replacement
Cosa ti serve
  1. Altec Lansing BoomJacket Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Altec Lansing BoomJacket Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the outer black rubber housing of the speaker.
  3. Altec Lansing BoomJacket Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the inner blue rubber housing from the speaker.
  4. Altec Lansing BoomJacket Speaker Replacement: passo 4, immagine 1 di 1
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Altec Lansing BoomJacket Speaker Replacement: passo 5, immagine 1 di 2 Altec Lansing BoomJacket Speaker Replacement: passo 5, immagine 2 di 2
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Altec Lansing BoomJacket Speaker Replacement: passo 6, immagine 1 di 1
    • Using the size PH1 screwdriver remove the screws (4 around each speaker).
  7. Altec Lansing BoomJacket Speaker Replacement: passo 7, immagine 1 di 1
    • Pull the case apart and you will be able to see all the components inside the speaker.
  8. Altec Lansing BoomJacket Speaker Replacement: passo 8, immagine 1 di 1
    • Remove the speakers (not entirely because of the wiring) by gently pulling each speaker up.
Conclusione
2 Commenti
Where do I find the correct part to replace the charging port on my boom jacket?
Rockstar - Replica
1.1" External Magnetic Type Round Slim Plastic Shell Speaker 8 Ohm 0.25W 2 Pcs
Eeshton -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 741
