Salta al contenuto principale
Altec Lansing BoomJacket Power Button Replacement
Cosa ti serve
  1. Altec Lansing BoomJacket Power Button Replacement, Case Removal: passo 1, immagine 1 di 1
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Altec Lansing BoomJacket Power Button Replacement: passo 2, immagine 1 di 1
    • Remove the outer black rubber housing of the speaker.
  3. Altec Lansing BoomJacket Power Button Replacement: passo 3, immagine 1 di 1
    • Remove the inner blue rubber housing from the speaker.
  4. Altec Lansing BoomJacket Power Button Replacement: passo 4, immagine 1 di 1
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Altec Lansing BoomJacket Power Button Replacement: passo 5, immagine 1 di 2 Altec Lansing BoomJacket Power Button Replacement: passo 5, immagine 2 di 2
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Altec Lansing BoomJacket Power Button Replacement: passo 6, immagine 1 di 1
    • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
  7. Altec Lansing BoomJacket Power Button Replacement: passo 7, immagine 1 di 1
    • Pull the case apart and you will be able to see all the components inside the speaker.
  8. Altec Lansing BoomJacket Power Button Replacement, Power Button: passo 8, immagine 1 di 1
    • The battery will be sitting right behind the speakers when the case is open.
    This is stupid. I have 2 and these speakers suck. For $30 why do I have to go and diagnose and fix this crap,, ripoff
    Rach - Replica
  9. Altec Lansing BoomJacket Power Button Replacement: passo 9, immagine 1 di 2 Altec Lansing BoomJacket Power Button Replacement: passo 9, immagine 2 di 2
    • Unplug and disconnect the battery from the motherboard.
  10. Altec Lansing BoomJacket Power Button Replacement: passo 10, immagine 1 di 1
    • Using a size PH1 screwdriver, remove the two screws.
  11. Altec Lansing BoomJacket Power Button Replacement: passo 11, immagine 1 di 2 Altec Lansing BoomJacket Power Button Replacement: passo 11, immagine 2 di 2
    • You will now see the motherboard for the power button.
    • Remove the 2 screws holding the motherboard into place.
  12. Altec Lansing BoomJacket Power Button Replacement: passo 12, immagine 1 di 1
    • Pick up the motherboard and take it out of the slot.
  13. Altec Lansing BoomJacket Power Button Replacement: passo 13, immagine 1 di 1
    • Disconnect the power button motherboard from the speaker motherboard.
Conclusione
Altre 8 persone hanno completato questa guida.
Un commento
Current speaker won’t turn on even though charging light looks all good so came across these instructions.
Thinking it’s the power button on my speaker that’s the issue.
Assuming these instructions are assuming you are replacing the power button motherboard? Where could I source one?
Cat Moure - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 86
Tutti i Tempi: 20,499
