Salta al contenuto principale
Altec Lansing BoomJacket 2 Speaker Replacement
Cosa ti serve
  1. Altec Lansing BoomJacket 2 Speaker Replacement, Altec Lansing BoomJacket 2 Disassembly: passo 1, immagine 1 di 2 Altec Lansing BoomJacket 2 Speaker Replacement, Altec Lansing BoomJacket 2 Disassembly: passo 1, immagine 2 di 2
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Speaker Replacement: passo 2, immagine 1 di 2 Altec Lansing BoomJacket 2 Speaker Replacement: passo 2, immagine 2 di 2
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Speaker Replacement: passo 3, immagine 1 di 1
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Speaker Replacement: passo 4, immagine 1 di 2 Altec Lansing BoomJacket 2 Speaker Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Speaker Replacement: passo 5, immagine 1 di 1
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Speaker Replacement: passo 6, immagine 1 di 1
    • Gently pull apart the front panel from the base of the speaker.
  7. Altec Lansing BoomJacket 2 Speaker Replacement, Speaker: passo 7, immagine 1 di 2 Altec Lansing BoomJacket 2 Speaker Replacement, Speaker: passo 7, immagine 2 di 2
    • Unscrew the four screws holding the speaker in place.
  8. Altec Lansing BoomJacket 2 Speaker Replacement: passo 8, immagine 1 di 2 Altec Lansing BoomJacket 2 Speaker Replacement: passo 8, immagine 2 di 2
    • Unscrew the two screws on the smaller speaker.
    • Pull the small speaker through the larger speaker hole.
Conclusione
Zach Braaten
Membro da: 07/12/18
537 Reputazione
4 Guide realizzate
UW Tacoma, Team S1-G4, Cardinal Summer 2018 Membro di UW Tacoma, Team S1-G4, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G4
4 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 31
Tutti i Tempi: 719
