Salta al contenuto principale
Altec Lansing BoomJacket 2 Battery Replacement
Cosa ti serve
  1. Altec Lansing BoomJacket 2 Battery Replacement, Altec Lansing BoomJacket 2 Disassembly: passo 1, immagine 1 di 2 Altec Lansing BoomJacket 2 Battery Replacement, Altec Lansing BoomJacket 2 Disassembly: passo 1, immagine 2 di 2
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Battery Replacement: passo 2, immagine 1 di 2 Altec Lansing BoomJacket 2 Battery Replacement: passo 2, immagine 2 di 2
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Battery Replacement: passo 3, immagine 1 di 1
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Battery Replacement: passo 4, immagine 1 di 2 Altec Lansing BoomJacket 2 Battery Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Battery Replacement: passo 5, immagine 1 di 1
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Battery Replacement: passo 6, immagine 1 di 1
    • Gently pull apart the front panel from the base of the speaker.
  7. Altec Lansing BoomJacket 2 Battery Replacement, Battery: passo 7, immagine 1 di 1
    • The battery will be in the middle of the speaker when the case is open.
  8. Altec Lansing BoomJacket 2 Battery Replacement: passo 8, immagine 1 di 1
    • Pull firmly from both sides of the pin to disconnect the battery cable from the motherboard.
    • Pull battery up and away from speaker without catching any other components.
    • Motherboards have fragile components and can easily be damaged if they are hit or pulled on while extracting other parts.
Conclusione
Altre 2 persone hanno completato questa guida.
Zach Braaten
Membro da: 07/12/18
537 Reputazione
4 Guide realizzate
UW Tacoma, Team S1-G4, Cardinal Summer 2018 Membro di UW Tacoma, Team S1-G4, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G4
4 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,920
