Salta al contenuto principale
Alpine MRV-M500 Electrolytic Capacitor Replacement
Cosa ti serve
  1. Alpine MRV-M500 Electrolytic Capacitor Replacement, Electrolytic Capacitor: passo 1, immagine 1 di 3 Alpine MRV-M500 Electrolytic Capacitor Replacement, Electrolytic Capacitor: passo 1, immagine 2 di 3 Alpine MRV-M500 Electrolytic Capacitor Replacement, Electrolytic Capacitor: passo 1, immagine 3 di 3
    • Remove all the Phillips 10.0mm and 7.0mm screws on the outside of the case.
    • Make sure the device has been powered off and disconnected from the power source for at least a day before touching the electronic components.
  2. Alpine MRV-M500 Electrolytic Capacitor Replacement: passo 2, immagine 1 di 3 Alpine MRV-M500 Electrolytic Capacitor Replacement: passo 2, immagine 2 di 3 Alpine MRV-M500 Electrolytic Capacitor Replacement: passo 2, immagine 3 di 3
    • Remove all Phillips 7.5mm, 12.5mm, and 10.5mm screws holding the circuit board to the case.
    • Remove the circuit board from the case.
  3. Alpine MRV-M500 Electrolytic Capacitor Replacement: passo 3, immagine 1 di 2 Alpine MRV-M500 Electrolytic Capacitor Replacement: passo 3, immagine 2 di 2
    • Find the faulty capacitor.
    • Flip the board over and locate the corresponding pins.
    • If the faulty capacitor is one of the smaller ones, it may be too difficult to replace and replacing the circuit board itself may be easier.
    • Make sure that the capacitance and voltage rating of the new capacitor match that of the original.
  4. Alpine MRV-M500 Electrolytic Capacitor Replacement: passo 4, immagine 1 di 1
    • Desolder the pins to remove the capacitor.
    • Solder the new capacitor into its place.
    • Make sure the polarity of the new capacitor matches the previous polarity.
Conclusione
Altre 3 persone hanno completato questa guida.
Eric Gaulke
Membro da: 09/17/18
623 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,548
