Salta al contenuto principale
Alienware m15 R6 SSD slot two Replacement
Cosa ti serve
  1. Alienware m15 R6 SSD slot two Replacement, Base Cover: passo 1, immagine 1 di 1
    • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
    • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
    • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
  2. Alienware m15 R6 SSD slot two Replacement: passo 2, immagine 1 di 1
    • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Alienware m15 R6 SSD slot two Replacement: passo 3, immagine 1 di 1
    • Disconnect the battery cable from the system board.
    • Turn your computer over and press the power button for 20 seconds to drain the flea power
  4. Alienware m15 R6 SSD slot two Replacement, Removing the solid-state drive in SSD slot two: passo 4, immagine 1 di 2 Alienware m15 R6 SSD slot two Replacement, Removing the solid-state drive in SSD slot two: passo 4, immagine 2 di 2
    • Remove the two screws (M2x4) that secure the thermal shield to the solid-state drive and system board.
    • Lift the thermal shield off the solid-state drive.
    • Slide and lift the solid-state drive off the solid-state drive slot on the system board.
  5. Alienware m15 R6 SSD slot two Replacement, Procedure to move the screw mount in SSD slot two: passo 5, immagine 1 di 1
    • Slide to remove the screw mount from the palm-rest and keyboard assembly.
    • Slide the screw mount into the other screw mount slot on the palm-rest and keyboard assembly.
Conclusione
Andrzej
Membro da: 02/17/23
1.702 Reputazione
18 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 493
