Salta al contenuto principale
Alienware X51 Motherboard Replacement
Cosa ti serve
  1. Alienware X51 Motherboard Replacement, Front Panel: passo 1, immagine 1 di 1
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Motherboard Replacement: passo 2, immagine 1 di 1
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Motherboard Replacement, Fan: passo 3, immagine 1 di 2 Alienware X51 Motherboard Replacement, Fan: passo 3, immagine 2 di 2
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
  4. Alienware X51 Motherboard Replacement: passo 4, immagine 1 di 1
    • Disconnect the Molex KK connector from the fan.
  5. Alienware X51 Motherboard Replacement: passo 5, immagine 1 di 3 Alienware X51 Motherboard Replacement: passo 5, immagine 2 di 3 Alienware X51 Motherboard Replacement: passo 5, immagine 3 di 3
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
  6. Alienware X51 Motherboard Replacement, Disc Drive: passo 6, immagine 1 di 2 Alienware X51 Motherboard Replacement, Disc Drive: passo 6, immagine 2 di 2
    • Disconnect the optical-drive data and power cable.
  7. Alienware X51 Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
    • Remove the disc drive from the PC.
  8. Alienware X51 Motherboard Replacement, RAM: passo 8, immagine 1 di 3 Alienware X51 Motherboard Replacement, RAM: passo 8, immagine 2 di 3 Alienware X51 Motherboard Replacement, RAM: passo 8, immagine 3 di 3
    • Pull apart the clips that hold the RAM sticks in place.
    • Remove the RAM sticks.
  9. Alienware X51 Motherboard Replacement, Heatsink: passo 9, immagine 1 di 3 Alienware X51 Motherboard Replacement, Heatsink: passo 9, immagine 2 di 3 Alienware X51 Motherboard Replacement, Heatsink: passo 9, immagine 3 di 3
    • Loosen the four 10.0 mm screws around the heatsink with a Phillips #1 screwdriver until you hear a click.
    • These are captive screws and cannot be fully removed.
    • Remove the heatsink by gently prying and lifting it up.
  10. Alienware X51 Motherboard Replacement, Motherboard: passo 10, immagine 1 di 2 Alienware X51 Motherboard Replacement, Motherboard: passo 10, immagine 2 di 2
    • Remove the single 1.0 mm screw with a Phillips #1 screwdriver.
    • Firmly remove the internal PC system by lifting it out of the PC.
  11. Alienware X51 Motherboard Replacement: passo 11, immagine 1 di 2 Alienware X51 Motherboard Replacement: passo 11, immagine 2 di 2
    • Loosen the four 1.0 mm screws holding down the motherboard using a Phillips #1 screwdriver.
  12. Alienware X51 Motherboard Replacement: passo 12, immagine 1 di 2 Alienware X51 Motherboard Replacement: passo 12, immagine 2 di 2
    • Disconnect the two SATA plugs going into the motherboard processor.
  13. Alienware X51 Motherboard Replacement: passo 13, immagine 1 di 1
    • Disconnect the rectangular power supply plug from the motherboard into the other circuit board.
  14. Alienware X51 Motherboard Replacement: passo 14, immagine 1 di 1
    • Disconnect the bundled cable connector going into the motherboard.
  15. Alienware X51 Motherboard Replacement: passo 15, immagine 1 di 1
    • Disconnect the white bundled cable connector from the motherboard.
  16. Alienware X51 Motherboard Replacement: passo 16, immagine 1 di 1
    • Disconnect the rectangular yellow bundled cable connector plug going into the motherboard.
  17. Alienware X51 Motherboard Replacement: passo 17, immagine 1 di 1
    • Disconnect the power supply.
  18. Alienware X51 Motherboard Replacement: passo 18, immagine 1 di 1
    • Disconnect the rectangular white bundled cable connector going into the motherboard.
  19. Alienware X51 Motherboard Replacement: passo 19, immagine 1 di 2 Alienware X51 Motherboard Replacement: passo 19, immagine 2 di 2
    • Gently slide and lift out the motherboard from the PC.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 49
Ultimi 30 Giorni: 100
Tutti i Tempi: 702
