Salta al contenuto principale
Alienware X51 Fan Replacement
Cosa ti serve
  1. Alienware X51 Fan Replacement, Front Panel: passo 1, immagine 1 di 1
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Fan Replacement: passo 2, immagine 1 di 1
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Fan Replacement, Fan: passo 3, immagine 1 di 2 Alienware X51 Fan Replacement, Fan: passo 3, immagine 2 di 2
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
  4. Alienware X51 Fan Replacement: passo 4, immagine 1 di 1
    • Disconnect the Molex KK connector from the fan.
  5. Alienware X51 Fan Replacement: passo 5, immagine 1 di 3 Alienware X51 Fan Replacement: passo 5, immagine 2 di 3 Alienware X51 Fan Replacement: passo 5, immagine 3 di 3
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 243
