Salta al contenuto principale
Alienware X51 Disc Drive Replacement
Cosa ti serve
  1. Alienware X51 Disc Drive Replacement, Front Panel: passo 1, immagine 1 di 1
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Disc Drive Replacement: passo 2, immagine 1 di 1
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Disc Drive Replacement, Disc Drive: passo 3, immagine 1 di 2 Alienware X51 Disc Drive Replacement, Disc Drive: passo 3, immagine 2 di 2
    • Disconnect the optical-drive data and power cable.
  4. Alienware X51 Disc Drive Replacement: passo 4, immagine 1 di 1
    • Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
    • Remove the disc drive from the PC.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 207
