Salta al contenuto principale
Alienware P18G M14X R1 RAM Replacement
Cosa ti serve
  1. Alienware P18G M14X R1 RAM Replacement, Back Cover: passo 1, immagine 1 di 1
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 RAM Replacement: passo 2, immagine 1 di 1
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 RAM Replacement: passo 3, immagine 1 di 1
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 RAM Replacement, RAM: passo 4, immagine 1 di 1
    • Unscrew the two 6.35 mm using the PH1 screw driver.
  5. Alienware P18G M14X R1 RAM Replacement: passo 5, immagine 1 di 2 Alienware P18G M14X R1 RAM Replacement: passo 5, immagine 2 di 2
    • Lift the plate and remove it to uncover the RAM sticks.
  6. Alienware P18G M14X R1 RAM Replacement: passo 6, immagine 1 di 1
    • Push outward on the prongs that secure the RAM stick in the slots.
    • After releasing the prongs the rams stick will rise up.
  7. Alienware P18G M14X R1 RAM Replacement: passo 7, immagine 1 di 1
    • Be very gentle in this step, making sure to not damage anything.
    • Pull the RAM stick out of its housing.
  8. Alienware P18G M14X R1 RAM Replacement: passo 8, immagine 1 di 1
  9. Alienware P18G M14X R1 RAM Replacement: passo 9, immagine 1 di 1
    • Pull the second ram stick out of its housing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,032
