Salta al contenuto principale
Alienware P18G M14X R1 Battery Replacement
Cosa ti serve
  1. Alienware P18G M14X R1 Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 Battery Replacement: passo 2, immagine 1 di 1
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 Battery Replacement: passo 3, immagine 1 di 1
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Make sure the laptop is turned off before starting.
    • Using PH1 screwdriver loosen the two screws on the right of the battery.
    • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
  5. Alienware P18G M14X R1 Battery Replacement: passo 5, immagine 1 di 2 Alienware P18G M14X R1 Battery Replacement: passo 5, immagine 2 di 2
    • Pull battery up using the tab provided.
  6. Alienware P18G M14X R1 Battery Replacement: passo 6, immagine 1 di 1
    • Disconnect the clip connecting the battery to the computer.
    • Set battery aside.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,975
