Salta al contenuto principale
Alienware M17x P01E Coin Cell Battery Replacement
Cosa ti serve
  1. Alienware M17x P01E Coin Cell Battery  Replacement, Battery: passo 1, immagine 1 di 1
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Alienware M17x P01E Coin Cell Battery  Replacement: passo 2, immagine 1 di 2 Alienware M17x P01E Coin Cell Battery  Replacement: passo 2, immagine 2 di 2
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Alienware M17x P01E Coin Cell Battery  Replacement, Compartment Door: passo 3, immagine 1 di 1
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Alienware M17x P01E Coin Cell Battery  Replacement: passo 4, immagine 1 di 2 Alienware M17x P01E Coin Cell Battery  Replacement: passo 4, immagine 2 di 2
    • Use your hand to gently lift and remove the compartment door.
  5. Alienware M17x P01E Coin Cell Battery  Replacement, Coin Cell Battery: passo 5, immagine 1 di 1
    • Gently pull on the coin cell battery cable to disconnect it from the laptop.
  6. Alienware M17x P01E Coin Cell Battery  Replacement: passo 6, immagine 1 di 1
    • Pull on the battery to remove.
Conclusione
Jose
Membro da: 09/19/18
324 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 509
