Salta al contenuto principale
Alienware M17x Motherboard Replacement
Cosa ti serve
  1. Alienware M17x Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Alienware M17x Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Alienware M17x Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
  3. Alienware M17x Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
  4. Alienware M17x Motherboard Replacement: passo 4, immagine 1 di 2 Alienware M17x Motherboard Replacement: passo 4, immagine 2 di 2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
  5. Alienware M17x Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove the following screws using a Phillips #0 screwdriver to free the motherboard from the rest of the internal components.
    • A Magnetic Project Mat is recommended to keep track of screws and removed parts.
    • Twelve 5.5 mm Phillips #0 main frame screws.
    • Six 3.5 mm Phillips #0 fan screws.
    • Four 3.5 mm Phillips #0 internal compartment screws.
    • Eight 3.5 mm Phillips #0 Hard Drive screws.
    • Four 3.5 mm Phillips #0 CD Drive screws.
    • After removing the screws NOT marked in red, each corresponding component can be removed, but it is not recommended for this guide.
  6. Alienware M17x Motherboard Replacement: passo 6, immagine 1 di 3 Alienware M17x Motherboard Replacement: passo 6, immagine 2 di 3 Alienware M17x Motherboard Replacement: passo 6, immagine 3 di 3
    • Flip the laptop over so that the Alienware logo is facing the ceiling and open the lid exposing the screen and keyboard.
    • Use a plastic opening tool to pry the keyboard from the base of the computer.
  7. Alienware M17x Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove five 3.5 mm Phillips #0 screws from the motherboard.
    • Unplug the consumer IR cables on the consumer IR board using a plastic opening tool.
    • Lift the motherboard at an angle and remove it from the computer base.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,775
