Salta al contenuto principale
Alienware M17x Hard Drive Replacement
Cosa ti serve
  1. Alienware M17x Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Alienware M17x Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Alienware M17x Hard Drive Replacement: passo 2, immagine 1 di 1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
  3. Alienware M17x Hard Drive Replacement: passo 3, immagine 1 di 1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
  4. Alienware M17x Hard Drive Replacement: passo 4, immagine 1 di 2 Alienware M17x Hard Drive Replacement: passo 4, immagine 2 di 2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
  5. Alienware M17x Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 1
    • With the laptop flipped over, cover removed, and battery removed; continue by locating your hard drive(s).
  6. Alienware M17x Hard Drive Replacement: passo 6, immagine 1 di 3 Alienware M17x Hard Drive Replacement: passo 6, immagine 2 di 3 Alienware M17x Hard Drive Replacement: passo 6, immagine 3 di 3
    • Remove the eight 3.5 mm Phillips #0 screws.
    • Remove the hard drive(s), using the Plastic Opening Tool by lifting on the edges and pulling the hard drive up and out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,352
