Salta al contenuto principale
Alienware M17-R1 RAM Replacement
Cosa ti serve
  1. Alienware M17-R1 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Push the slider until the battery is released from its socket.
  2. Alienware M17-R1 RAM Replacement: passo 2, immagine 1 di 1
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
  3. Alienware M17-R1 RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Place laptop down on a hard flat surface to begin the disassembly.
  4. Alienware M17-R1 RAM Replacement: passo 4, immagine 1 di 2 Alienware M17-R1 RAM Replacement: passo 4, immagine 2 di 2
    • Remove the nine 3 mm screws that secure the cover using a Phillips #1 screwdriver.
  5. Alienware M17-R1 RAM Replacement: passo 5, immagine 1 di 1
    • Once the cover is removed, locate the RAM compartment to begin the replacement.
  6. Alienware M17-R1 RAM Replacement: passo 6, immagine 1 di 2 Alienware M17-R1 RAM Replacement: passo 6, immagine 2 di 2
    • After locating the RAM, gently pull the two metal clips outward and lift the RAM card out of its socket.
    • The card will pop up once it has been released and can be removed.
  7. Alienware M17-R1 RAM Replacement: passo 7, immagine 1 di 1
    • To insert the new RAM, place it on top of the socket and carefully apply downward pressure until it snaps into place.
Conclusione
LXA054
Membro da: 10/09/18
337 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 661
