Salta al contenuto principale
Alienware M17-R1 CPU Cooler Replacement
Cosa ti serve
  1. Alienware M17-R1 CPU Cooler Replacement, Battery: passo 1, immagine 1 di 1
    • Push the slider until the battery is released from its socket.
  2. Alienware M17-R1 CPU Cooler Replacement: passo 2, immagine 1 di 1
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
  3. Alienware M17-R1 CPU Cooler Replacement, CPU Cooler: passo 3, immagine 1 di 1
    • First begin by placing the laptop on a hard flat surface.
    • Remove the nine 3 mm screws that secure the back panel using a Phillips #1 screwdriver.
  4. Alienware M17-R1 CPU Cooler Replacement: passo 4, immagine 1 di 1
    • Once the cover has been removed, locate the CPU Cooler to begin the replacement.
  5. Alienware M17-R1 CPU Cooler Replacement: passo 5, immagine 1 di 1
    • Remove the six 7 mm screws using a Phillips #1 and then use the pry tool to unplug the fan before removing the CPU Cooler.
    • Screws 1 through 4 are integrated into the cooler and will come all the way out.
  6. Alienware M17-R1 CPU Cooler Replacement: passo 6, immagine 1 di 1
    • Once all screws have been removed and the cooler has been unplugged, gently lift the cooler out of its compartment to install the new cooling fan.
Conclusione
LXA054
Membro da: 10/09/18
337 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 751
