Salta al contenuto principale
Introduzione
This guide provides instructions on how to upgrade or replace the hard drive in an Alienware M15x.
  1. Remove the battery by sliding the latch to the left and pulling the battery up. Remove the battery by sliding the latch to the left and pulling the battery up. Remove the battery by sliding the latch to the left and pulling the battery up.
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip. Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
  3. Slide the compartment door towards the front of the computer and lift. Slide the compartment door towards the front of the computer and lift. Slide the compartment door towards the front of the computer and lift.
    • Slide the compartment door towards the front of the computer and lift.
  4. Use Phillips #1 screwdriver to loosen the four screws on the hard drive enclosure.
    • Use Phillips #1 screwdriver to loosen the four screws on the hard drive enclosure.
  5. Once the screws are loosened use the "PULL" tab to remove the current hard drive from the computer. Once the screws are loosened use the "PULL" tab to remove the current hard drive from the computer.
    • Once the screws are loosened use the "PULL" tab to remove the current hard drive from the computer.
  6. Remove the four small screws indicated to remove the casing to the hard drive. Remove the four small screws indicated to remove the casing to the hard drive.
    • Remove the four small screws indicated to remove the casing to the hard drive.
  7. Now take off the SATA converter and then connect it to the drive you would like to replace it with.
    • Now take off the SATA converter and then connect it to the drive you would like to replace it with.
Conclusione
David Sann
Membro da: 22/01/2018
111 Reputazione
1 Guida realizzata
Cal Poly, Team S11-G3, Banghart Winter 2018 Membro di Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 576
