Salta al contenuto principale
Alienware M15x GPU Replacement
Cosa ti serve
  1. Alienware M15x GPU Replacement, GPU: passo 1, immagine 1 di 1
    • Turn the laptop over so that the bottom is facing upward.
  2. Alienware M15x GPU Replacement: passo 2, immagine 1 di 1
    • Release the battery latch and flip the battery out.
  3. Alienware M15x GPU Replacement: passo 3, immagine 1 di 2 Alienware M15x GPU Replacement: passo 3, immagine 2 di 2
    • Remove the two 4mm screws using a Phillips #1 screwdriver.
    • Remove the compartment door by sliding it away from the battery.
  4. Alienware M15x GPU Replacement: passo 4, immagine 1 di 1
    • Remove the four 4mm screws with the Phillips #1 screwdriver.
  5. Alienware M15x GPU Replacement: passo 5, immagine 1 di 1
    • Position the laptop vertically so that the hinge is facing up and the laptop is slightly open toward the ground
    • The laptop position should resemble an upside-down V shape.
    • Locate the panel and pry open using a plastic opening tool.
  6. Alienware M15x GPU Replacement: passo 6, immagine 1 di 3 Alienware M15x GPU Replacement: passo 6, immagine 2 di 3 Alienware M15x GPU Replacement: passo 6, immagine 3 di 3
    • Position the laptop normally, with the bottom on the ground and the screen flipped up towards you.
    • Lift the power button panel using the plastic opening tool.
    • Disconnect the ribbon cable by using tweezers to unclip the two small black clips. Remove power button panel.
  7. Alienware M15x GPU Replacement: passo 7, immagine 1 di 1
    • Remove the two 4mm screws with a Phillips #1 screwdriver.
  8. Alienware M15x GPU Replacement: passo 8, immagine 1 di 2 Alienware M15x GPU Replacement: passo 8, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the 4mm screw from the exhaust port cover.
    • Remove the exhaust port cover entirely.
  9. Alienware M15x GPU Replacement: passo 9, immagine 1 di 3 Alienware M15x GPU Replacement: passo 9, immagine 2 di 3 Alienware M15x GPU Replacement: passo 9, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the two 3mm screws holding the fan in place, then unclip the electrical connection using tweezers.
  10. Alienware M15x GPU Replacement: passo 10, immagine 1 di 1
    • Remove the heat sink by loosening the 4 screws with a Phillips #0 screwdriver.
  11. Alienware M15x GPU Replacement: passo 11, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the two screws.
    • Remove the GPU from the laptop.
    • When replacing the GPU, it is important to reapply thermal paste in a small line along the length of the chip.
Conclusione
Tomas Kronmark
Membro da: 01/22/18
193 Reputazione
1 Guida realizzata
Cal Poly, Team S11-G3, Banghart Winter 2018 Membro di Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,616
