Salta al contenuto principale
Alienware M14xR2 Status-Light Board Replacement
Cosa ti serve
  1. Alienware M14xR2 Status-Light Board Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Status-Light Board Replacement: passo 2, immagine 1 di 3 Alienware M14xR2 Status-Light Board Replacement: passo 2, immagine 2 di 3 Alienware M14xR2 Status-Light Board Replacement: passo 2, immagine 3 di 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Status-Light Board Replacement: passo 3, immagine 1 di 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Status-Light Board Replacement: passo 4, immagine 1 di 3 Alienware M14xR2 Status-Light Board Replacement: passo 4, immagine 2 di 3 Alienware M14xR2 Status-Light Board Replacement: passo 4, immagine 3 di 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 Status-Light Board Replacement, Turning the Palm-Rest Assembly Over: passo 5, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Turn the palm-rest assembly over.
  6. Alienware M14xR2 Status-Light Board Replacement, Remove the Cable: passo 6, immagine 1 di 1
    • Note the routing of status-light board cable and remove the cable from the routing guides.
    • NOTE: If the status-light board cable is under the speakers cable, remove the speakers cable first and then remove the status-light board cable.
  7. Alienware M14xR2 Status-Light Board Replacement, Turn the Palm-Rest Assembly Over: passo 7, immagine 1 di 1
  8. Alienware M14xR2 Status-Light Board Replacement, Remove the Screw: passo 8, immagine 1 di 1
    • Remove the screw that secures the status-light board to the palm-rest assembly.
  9. Alienware M14xR2 Status-Light Board Replacement, Lifting the Status-Light Board: passo 9, immagine 1 di 1
    • Carefully lift the status-light board and release its cable from the slot on the palm-rest assembly.
  10. Alienware M14xR2 Status-Light Board Replacement, Slide the Status-Light Board Cable: passo 10, immagine 1 di 1
    • Slide the NEW status-light board cable through the slot in the palm-rest assembly.
  11. Alienware M14xR2 Status-Light Board Replacement, Align the Slot: passo 11, immagine 1 di 1
    • Align the slot on the status-light board with the alignment post on the palm-rest assembly.
  12. Alienware M14xR2 Status-Light Board Replacement, Replace the Screw: passo 12, immagine 1 di 1
    • Replace the screw that secures the status-light board to the palm-rest assembly.
  13. Alienware M14xR2 Status-Light Board Replacement, Turning the Palm-Rest Assembly Over: passo 13, immagine 1 di 1
  14. Alienware M14xR2 Status-Light Board Replacement, Routing the Status-Light Board Cable: passo 14, immagine 1 di 1
    • Route the status-light board cable through the routing guides on the palm-rest assembly.
Conclusione
Terrence15
Membro da: 12/18/17
79.091 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
Un commento
Völliges Durcheinander und unvollständig
Robert Fleischhauer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 660
