Salta al contenuto principale
Alienware M14xR2 Optical Drive Replacement
Cosa ti serve
  1. Alienware M14xR2 Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Optical Drive Replacement: passo 2, immagine 1 di 3 Alienware M14xR2 Optical Drive Replacement: passo 2, immagine 2 di 3 Alienware M14xR2 Optical Drive Replacement: passo 2, immagine 3 di 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Optical Drive Replacement: passo 3, immagine 1 di 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Optical Drive Replacement: passo 4, immagine 1 di 3 Alienware M14xR2 Optical Drive Replacement: passo 4, immagine 2 di 3 Alienware M14xR2 Optical Drive Replacement: passo 4, immagine 3 di 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 Optical Drive Replacement, Optical Drive: passo 5, immagine 1 di 3 Alienware M14xR2 Optical Drive Replacement, Optical Drive: passo 5, immagine 2 di 3 Alienware M14xR2 Optical Drive Replacement, Optical Drive: passo 5, immagine 3 di 3
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
Conclusione
Jordan Ramsey
Membro da: 09/30/13
402 Reputazione
1 Guida realizzata
Cal Poly, Team 13-4, Forte Fall 2013 Membro di Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,885
