Salta al contenuto principale
Alienware M14xR2 Battery Replacement
Cosa ti serve
  1. Alienware M14xR2 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Battery Replacement: passo 2, immagine 1 di 3 Alienware M14xR2 Battery Replacement: passo 2, immagine 2 di 3 Alienware M14xR2 Battery Replacement: passo 2, immagine 3 di 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Battery Replacement: passo 3, immagine 1 di 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Battery Replacement: passo 4, immagine 1 di 3 Alienware M14xR2 Battery Replacement: passo 4, immagine 2 di 3 Alienware M14xR2 Battery Replacement: passo 4, immagine 3 di 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
Conclusione
Altre 10 persone hanno completato questa guida.
Cal Poly, Team 13-4, Forte Fall 2013 Membro di Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 10,758
