Salta al contenuto principale
Alienware M11xR2 Coin-Cell Battery Replacement
Cosa ti serve
  1. Alienware M11xR2 Coin-Cell Battery Replacement, Removing the Base Cover: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Coin-Cell Battery Replacement, Loosen the Screws: passo 2, immagine 1 di 1
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Coin-Cell Battery Replacement, Lifting the Base Cover: passo 3, immagine 1 di 1
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Coin-Cell Battery Replacement, Replacing the Base Cover: passo 4, immagine 1 di 1
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Coin-Cell Battery Replacement, Securing the Screws: passo 5, immagine 1 di 1
    • Tighten the eight screws that secure the base cover to the computer base.
  6. Alienware M11xR2 Coin-Cell Battery Replacement, Disconnecting Coin-Cell Battery: passo 6, immagine 1 di 1
    • Disconnect the coin-cell battery cable from the connector on the system board.
  7. Alienware M11xR2 Coin-Cell Battery Replacement, Prying The Coin-Cell Battery: passo 7, immagine 1 di 1
    • The coin-cell battery is glued to the system board. Using a plastic scribe, pry the coin-cell battery from the system board.
  8. Alienware M11xR2 Coin-Cell Battery Replacement, Placing New Coin-Cell Battery: passo 8, immagine 1 di 1
    • Use the adhesive on NEW the coin-cell battery and adhere it to the system board.
  9. Alienware M11xR2 Coin-Cell Battery Replacement, Connecting Cable: passo 9, immagine 1 di 1
    • Connect the coin-cell battery cable to the connector on the system board.
Conclusione
Altre 3 persone hanno completato questa guida.
darrius
Membro da: 03/26/18
5.213 Reputazione
30 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.984 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 490
