Salta al contenuto principale
Alienware M11xR2 Base Cover Replacement
Cosa ti serve
  1. Alienware M11xR2 Base Cover Replacement, Removing the Base Cover: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Base Cover Replacement, Loosen the Screws: passo 2, immagine 1 di 1
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Base Cover Replacement, Lifting the Base Cover: passo 3, immagine 1 di 1
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Base Cover Replacement, Replacing the Base Cover: passo 4, immagine 1 di 1
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Base Cover Replacement, Securing the Screws: passo 5, immagine 1 di 1
    • Tighten the eight screws that secure the base cover to the computer base.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
darrius
Membro da: 03/26/18
5.213 Reputazione
30 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 246
