Salta al contenuto principale
Alienware M11x Power-Button Board Replacement
Cosa ti serve
  1. Alienware M11x Power-Button Board Replacement, Removing the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the power button board to the palm rest assembly.
    Chiedi a FixBot
  2. Alienware M11x Power-Button Board Replacement, Lifting the Power Button Board: passo 2, immagine 1 di 1
    • Lift the power button board off the palm rest assembly.
    Chiedi a FixBot
  3. Alienware M11x Power-Button Board Replacement, Removing the Screws: passo 3, immagine 1 di 1
    • Place the power button board on the palm rest assembly and replace the two screws that secure the power button board to the palm rest assembly.
    • CAUTION: Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so may result in damage the computer.
    Chiedi a FixBot
Conclusione
Altre 2 persone hanno completato questa guida.
darrius
Membro da: 03/26/18
5.213 Reputazione
30 guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
45 Membri
2.002 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 23
Ultimi 30 giorni: 89
Tutti i Tempi: 803
