Introduzione
In this guide, we will be showing you how to remove and replace the Display Assembly.
Cosa ti serve
Loosen the two captive screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, pull the hard-drive assembly to disconnect the hard-drive assembly from the connector on the system board.
Lift the hard-drive assembly out of the computer base.
Remove the four screws that secure the hard drive to the hard-drive bracket.
Replace the four screws that secure the hard-drive to the hard-drive bracket.
Use the pull-tab to push the hard drive assembly and connect it to the connector on the system board.
Tighten the two captive screws that secure the hard-drive assembly to the computer base.
Altre 2 persone hanno completato questa guida.
