Salta al contenuto principale
Alienware Aurora M9700 Camera Replacement
Cosa ti serve
  1. Alienware Aurora M9700 Camera Replacement, Camera: passo 1, immagine 1 di 1
    • Open the device so the main screen is facing forward.
    • Locate the 8 rubber buttons around the bezel of the display and remove the rubber buttons with the metal spudger to expose the screws underneath.
    • Locate the 8 screws around the perimeter of the screen and unscrew them.
  2. Alienware Aurora M9700 Camera Replacement: passo 2, immagine 1 di 2 Alienware Aurora M9700 Camera Replacement: passo 2, immagine 2 di 2
    • Insert the plastic opening tool between the black and green frames to remove the display frame at the bottom of the display.
    • Slide the lock to the right when removing the display frame.
    • Remove the frame display.
  3. Alienware Aurora M9700 Camera Replacement: passo 3, immagine 1 di 2 Alienware Aurora M9700 Camera Replacement: passo 3, immagine 2 di 2
    • Now that the outer frame is removed, locate the two screws to the right and the left of the camera.
    • Remove the two screws freeing the camera of the brackets holding it in place.
    • Pry the camera upward from its designated location using the metal spudger.
  4. Alienware Aurora M9700 Camera Replacement: passo 4, immagine 1 di 2 Alienware Aurora M9700 Camera Replacement: passo 4, immagine 2 di 2
    • Unplug the wire connection between the camera and the laptop.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 265
