Salta al contenuto principale
Alienware Aurora M9700 Battery Replacement
  1. Alienware Aurora M9700 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn laptop over so that the bottom of the device is facing upward.
    • Locate the square battery pack on the bottom left corner.
  2. Alienware Aurora M9700 Battery Replacement: passo 2, immagine 1 di 2 Alienware Aurora M9700 Battery Replacement: passo 2, immagine 2 di 2
    • Notice a unlock emblem directly above the battery pack with a sliding lock button.
    • Using your finger, slide the button to the right, releasing the battery from its designated compartment.
  3. Alienware Aurora M9700 Battery Replacement: passo 3, immagine 1 di 2 Alienware Aurora M9700 Battery Replacement: passo 3, immagine 2 di 2
    • Now that the battery is free, use your finger to pry the battery upward, out of its designated compartment.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 351
