Salta al contenuto principale
Alienware Area-51m battery Replacement
Cosa ti serve
  1. Alienware Area-51m battery Replacement, battery: passo 1, immagine 1 di 3 Alienware Area-51m battery Replacement, battery: passo 1, immagine 2 di 3 Alienware Area-51m battery Replacement, battery: passo 1, immagine 3 di 3
    • turn off the laptop and remove all the cable connect to your laptop.
    • Place the back of the laptop up.
    • Remove 6 M2.5X8 computer base screws on the baseplate.
  2. Alienware Area-51m battery Replacement: passo 2, immagine 1 di 3 Alienware Area-51m battery Replacement: passo 2, immagine 2 di 3 Alienware Area-51m battery Replacement: passo 2, immagine 3 di 3
    • this is how it looks like when you take off the baseplate.
    • remove the cable connect with battery and main board.
    • Remove all 6 M2.5X5 battery screws around the battery.
  3. Alienware Area-51m battery Replacement: passo 3, immagine 1 di 2 Alienware Area-51m battery Replacement: passo 3, immagine 2 di 2
    • take off the battery and use your new battery to instead.
    • this is how it looks like when you take off the battery(for some reason i take off the hard disk as well, you don't need to care about that.)
  4. Alienware Area-51m battery Replacement: passo 4, immagine 1 di 3 Alienware Area-51m battery Replacement: passo 4, immagine 2 di 3 Alienware Area-51m battery Replacement: passo 4, immagine 3 di 3
    • now you just need to put everything back.And do not forget to put the screws back also.
Conclusione
When reassembling your device, follow the instructions in reverse order.
yupeng ge
Membro da: 01/20/21
1 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 37
Tutti i Tempi: 1,531
