Salta al contenuto principale
Alienware 17 R4 Wi-Fi Card Replacement
Cosa ti serve
  1. Alienware 17 R4 Wi-Fi Card Replacement, Base Cover: passo 1, immagine 1 di 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Wi-Fi Card Replacement: passo 2, immagine 1 di 2 Alienware 17 R4 Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Wi-Fi Card Replacement, Wi-Fi card: passo 3, immagine 1 di 1
    • Locate the WI-FI card.
  4. Alienware 17 R4 Wi-Fi Card Replacement: passo 4, immagine 1 di 2 Alienware 17 R4 Wi-Fi Card Replacement: passo 4, immagine 2 di 2
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
  5. Alienware 17 R4 Wi-Fi Card Replacement: passo 5, immagine 1 di 3 Alienware 17 R4 Wi-Fi Card Replacement: passo 5, immagine 2 di 3 Alienware 17 R4 Wi-Fi Card Replacement: passo 5, immagine 3 di 3
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
  6. Alienware 17 R4 Wi-Fi Card Replacement: passo 6, immagine 1 di 2 Alienware 17 R4 Wi-Fi Card Replacement: passo 6, immagine 2 di 2
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
Conclusione
Un commento
What is the logic for removing the HHD prior to removing the WIFI card?
Roderick Vanderzalm - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 68
Tutti i Tempi: 4,682
