Salta al contenuto principale
Alienware 17 R4 Solid State Drive (SSD) Replacement
Cosa ti serve
  1. Alienware 17 R4 Solid State Drive (SSD) Replacement, Base Cover: passo 1, immagine 1 di 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 2, immagine 1 di 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 2, immagine 2 di 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): passo 3, immagine 1 di 3 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): passo 3, immagine 2 di 3 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): passo 3, immagine 3 di 3
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 4, immagine 1 di 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 4, immagine 2 di 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 4, immagine 3 di 3
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 5, immagine 1 di 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 5, immagine 2 di 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 5, immagine 3 di 3
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 6, immagine 1 di 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 6, immagine 2 di 2
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: passo 7, immagine 1 di 2 Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: passo 7, immagine 2 di 2
    • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
  8. Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 8, immagine 1 di 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 8, immagine 2 di 2
    • Slide the solid state drive towards yourself to prevent damage to the card.
    How do I copy the contents of the old SSD to a new SSD. For example if I’m booting from my old SSD but want to update to a larger SSD.
    Shouldn’t step 1 be preserving my data? I give you a low score for lack of forethought. Guess another website might have pertinent information.
    Bill From Here - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Is it advised to pull the HDD before pulling the SSD or is this guide just written in a way to cover how to remove both of them?
John Crooks - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 57
Tutti i Tempi: 6,660
