Introduzione
This guide will show you how to replace the hard disk drive (HDD) for your Alienware 17 R4.
Cosa ti serve
Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
Altre 2 persone hanno completato questa guida.
