Salta al contenuto principale
Alienware 17 R4 Battery Replacement
Cosa ti serve
  1. Alienware 17 R4 Battery Replacement, Base Cover: passo 1, immagine 1 di 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Battery Replacement: passo 2, immagine 1 di 2 Alienware 17 R4 Battery Replacement: passo 2, immagine 2 di 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): passo 3, immagine 1 di 3 Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): passo 3, immagine 2 di 3 Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): passo 3, immagine 3 di 3
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Battery Replacement: passo 4, immagine 1 di 3 Alienware 17 R4 Battery Replacement: passo 4, immagine 2 di 3 Alienware 17 R4 Battery Replacement: passo 4, immagine 3 di 3
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Battery Replacement: passo 5, immagine 1 di 3 Alienware 17 R4 Battery Replacement: passo 5, immagine 2 di 3 Alienware 17 R4 Battery Replacement: passo 5, immagine 3 di 3
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Battery Replacement: passo 6, immagine 1 di 2 Alienware 17 R4 Battery Replacement: passo 6, immagine 2 di 2
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Battery Replacement, RAM: passo 7, immagine 1 di 3 Alienware 17 R4 Battery Replacement, RAM: passo 7, immagine 2 di 3 Alienware 17 R4 Battery Replacement, RAM: passo 7, immagine 3 di 3
    • Move the metal sidings outward to release the RAM card.
  8. Alienware 17 R4 Battery Replacement: passo 8, immagine 1 di 1
    • Slide the RAM card out towards yourself to remove it.
    • Repeat the same step for the RAM card above.
    • Slide the RAM card out carefully to avoid damaging it.
  9. Alienware 17 R4 Battery Replacement, Wi-Fi card: passo 9, immagine 1 di 1
    • Locate the WI-FI card.
  10. Alienware 17 R4 Battery Replacement: passo 10, immagine 1 di 2 Alienware 17 R4 Battery Replacement: passo 10, immagine 2 di 2
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
  11. Alienware 17 R4 Battery Replacement: passo 11, immagine 1 di 3 Alienware 17 R4 Battery Replacement: passo 11, immagine 2 di 3 Alienware 17 R4 Battery Replacement: passo 11, immagine 3 di 3
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
  12. Alienware 17 R4 Battery Replacement: passo 12, immagine 1 di 2 Alienware 17 R4 Battery Replacement: passo 12, immagine 2 di 2
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
    You don’t need to disconnect the WiFi card pins. I recommend leaving the antenna connections and just be careful when removing the frame in the next steps. The antenna connections are very fragile
    Colt Sammons - Replica
    I second that... Came off OK... Gently... I just can't seem to get them reconnected on renistall. Ridiculously difficult...
    Louie Candreva Jr -
  13. Alienware 17 R4 Battery Replacement, Solid State Drive: passo 13, immagine 1 di 2 Alienware 17 R4 Battery Replacement, Solid State Drive: passo 13, immagine 2 di 2
    • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
  14. Alienware 17 R4 Battery Replacement: passo 14, immagine 1 di 2 Alienware 17 R4 Battery Replacement: passo 14, immagine 2 di 2
    • Slide the solid state drive towards yourself to prevent damage to the card.
    How do I copy the contents of the old SSD to a new SSD. For example if I’m booting from my old SSD but want to update to a larger SSD.
    Shouldn’t step 1 be preserving my data? I give you a low score for lack of forethought. Guess another website might have pertinent information.
    Bill From Here - Replica
  15. Alienware 17 R4 Battery Replacement, Fan Shroud: passo 15, immagine 1 di 3 Alienware 17 R4 Battery Replacement, Fan Shroud: passo 15, immagine 2 di 3 Alienware 17 R4 Battery Replacement, Fan Shroud: passo 15, immagine 3 di 3
    • Remove the two M2.5x7 screws (2.44 mm) located on the rear panel using a PH1 screwdriver bit.
  16. Alienware 17 R4 Battery Replacement: passo 16, immagine 1 di 2 Alienware 17 R4 Battery Replacement: passo 16, immagine 2 di 2
    • Insert the plastic opening tool under the fan shroud to slowly lift it up.
    • Repeat process on the middle and opposite side.
  17. Alienware 17 R4 Battery Replacement: passo 17, immagine 1 di 2 Alienware 17 R4 Battery Replacement: passo 17, immagine 2 di 2
    • Firmly lift the plastic opening tool and pull the fan shroud towards you.
    • This will take a large amount of force and will not come out easily the first time.
    • Careful not to tear out the piece causing damage to the fan shroud
  18. Alienware 17 R4 Battery Replacement, Plastic Cover: passo 18, immagine 1 di 3 Alienware 17 R4 Battery Replacement, Plastic Cover: passo 18, immagine 2 di 3 Alienware 17 R4 Battery Replacement, Plastic Cover: passo 18, immagine 3 di 3
    • Unscrew the two M2x3 screws (1.9 mm) at the top right and top left of the laptop that hold the tron lights in place.
  19. Alienware 17 R4 Battery Replacement: passo 19, immagine 1 di 2 Alienware 17 R4 Battery Replacement: passo 19, immagine 2 di 2
    • Follow the wiring to unplug the tron lights.
    Please make sure that you remove the right and left Tron lights connector too.
    ricky saulo - Replica
    Don’t “unplug”. Simply unscrew the left and right units. Leave intact to removable frame.
  20. Alienware 17 R4 Battery Replacement: passo 20, immagine 1 di 3 Alienware 17 R4 Battery Replacement: passo 20, immagine 2 di 3 Alienware 17 R4 Battery Replacement: passo 20, immagine 3 di 3
    • Remove the fourteen M2.5XL8' screws (2.4 mm) located in the plastic cover using the PH1 screwdriver.
    The three other screws not highlighted are along the top, under where the fan shroud was located.
    CommandFix - Replica
  21. Alienware 17 R4 Battery Replacement: passo 21, immagine 1 di 1
    • Use the plastic opening tool to gently lift the sides of the cover.
  22. Alienware 17 R4 Battery Replacement: passo 22, immagine 1 di 2 Alienware 17 R4 Battery Replacement: passo 22, immagine 2 di 2
    • Slowly lift up the plastic cover.
  23. Alienware 17 R4 Battery Replacement, Battery: passo 23, immagine 1 di 3 Alienware 17 R4 Battery Replacement, Battery: passo 23, immagine 2 di 3 Alienware 17 R4 Battery Replacement, Battery: passo 23, immagine 3 di 3
    • Unscrew the four M2.5 screws (2.4 mm) with a PH1 screwdriver bit.
  24. Alienware 17 R4 Battery Replacement: passo 24, immagine 1 di 2 Alienware 17 R4 Battery Replacement: passo 24, immagine 2 di 2
    • Lift the battery up to remove it.
Conclusione
Altre 26 persone hanno completato questa guida.
7 Commenti
Very good guide, just one error, step 11 comes first then step 10. You can't lift the card before remove the screw.
alex.afnet - Replica
Great guide, no issues at all!
Glenn Bell - Replica
First time I've cracked opened up a computer in decades. This step by step guide gave me the confidence I needed! Thank you so much. It took me longer, about two hours with stopping to label screws and things but everything is up and running again. I'm so happy!
Michelle - Replica
I would not recommend disconnecting the wifi card. the connectors are tiny. if you screw up, best case you need a new wifi card, worst case you are going to need to replace the antenna, and that isn’t fun.
John Wohlwend - Replica
After the battery replacement? do we need to do anything else for calibration so that the Alienware knows that it is a fresh battery and battery cycle ... as i have heard that you need to repeat 3X the process of discharging and charging for calibration. or can we just plug and play? I am getting a new battery for mine soon. Thanks =)
Yannick Docq - Replica
Thank for the detailed instructions. However, am stuck with reattaching the wifi card cables, which won't click. I'll continue to try to attach, if not I'll need to send to Dell.....
plittke - Replica
Step 20 seems to fail to circle the top 3 screws on the first image. Would appreciate if that is updated, or I will see if I can contribute an update to that later.
GeekSquad Agent - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 76
Ultimi 30 Giorni: 340
Tutti i Tempi: 31,078
