Salta al contenuto principale
Alienware 17 R2 Base Panel Replacement
Cosa ti serve
  1. Alienware 17 R2 Base Panel Replacement, Close the Display: passo 2, immagine 1 di 1
    • Close the display and turn the computer over.
    • Make sure PC is turned off!
  2. Alienware 17 R2 Base Panel Replacement, Loosen Screws: passo 3, immagine 1 di 1
    • Loosen the captive screws that secure the base panel to the computer base.
  3. Alienware 17 R2 Base Panel Replacement, Releasing Tabs: passo 4, immagine 1 di 1
    • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
  4. Alienware 17 R2 Base Panel Replacement, Remove Base Panel: passo 5, immagine 1 di 1
    • Slide and remove the base panel from the computer base.
  5. Alienware 17 R2 Base Panel Replacement, Disconnect Battery Cable: passo 6, immagine 1 di 1
    • Disconnect the Battery cable from the system board.
    • Turn the computer over.
    • Press and hold power button for 5 seconds to ground the system board.
  6. Alienware 17 R2 Base Panel Replacement, Battery Cable: passo 9, immagine 1 di 1
    • Connect the battery cable to the system board.
  7. Alienware 17 R2 Base Panel Replacement, Tighten Screws: passo 10, immagine 1 di 1
    • Tighten the captive screws that secure the base panel to the computer base.
Conclusione
Terrence15
Membro da: 12/18/17
79.121 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 765
