Introduzione
This guide will help you locate where you SD card slot is on your Alcatel Pop 4 Plus and also show how to replace the SD card. All you need are your fingers to remove the outside cover and then slide the SD card in.
  1. Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off. Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  3. Use your fingers to pull out the Micro SD card.
    • Use your fingers to pull out the Micro SD card.
Conclusione
USF Tampa, Team S20-G6, Passmore Spring 2018 Membro di USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 79
