Salta al contenuto principale
Alcatel OneTouch Pop Icon Battery Replacement
Cosa ti serve
  1. Alcatel OneTouch Pop Icon Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the device
    • Flip the phone so that the screen is facing the surface you are working on
    • Aggressive prying may result in damaging the back panel or the internal contents of the phone.
    • Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
  2. Alcatel OneTouch Pop Icon Battery Replacement: passo 2, immagine 1 di 2 Alcatel OneTouch Pop Icon Battery Replacement: passo 2, immagine 2 di 2
    • Use your thumbnail to lift the battery from the phone.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,549
