Salta al contenuto principale
Alcatel OneTouch Evolve Battery Removal
Cosa ti serve
  1. Alcatel OneTouch Evolve Battery Removal, Locate the access tab: passo 1, immagine 1 di 1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
  2. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: passo 2, immagine 1 di 3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: passo 2, immagine 2 di 3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: passo 2, immagine 3 di 3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
  3. Alcatel OneTouch Evolve Battery Removal, Identify the Battery: passo 3, immagine 1 di 1
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
  4. Alcatel OneTouch Evolve Battery Removal, Removing the battery: passo 4, immagine 1 di 2 Alcatel OneTouch Evolve Battery Removal, Removing the battery: passo 4, immagine 2 di 2
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
Conclusione
Altre 12 persone hanno completato questa guida.
Brendan Egan
Membro da: 10/28/14
2.467 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 4-5, Miles Fall 2014 Membro di UMass Dartmouth, Team 4-5, Miles Fall 2014
UMASSD-MILES-F14S4G5
3 Membri
12 Guide realizzate
5 Commenti
Thanks 4 the info.
dennisp1964 - Replica
my phone is rooted
next time i,m delete all software
now my phone show only lock screen
how to install my old software
Noushad Marshi - Replica
Thank you very much!
Kath B - Replica
Easy and clear instructions! I am 95 yrs old and I found your instructions wonderful! Thank you Helen Spriggs
Helen Spriggs - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 12
Tutti i Tempi: 9,998
