Salta al contenuto principale
Alcatel OneTouch Elevate SIM Card Replacement
Cosa ti serve
  1. Alcatel OneTouch Elevate SIM Card Replacement, Battery: passo 1, immagine 1 di 3 Alcatel OneTouch Elevate SIM Card Replacement, Battery: passo 1, immagine 2 di 3 Alcatel OneTouch Elevate SIM Card Replacement, Battery: passo 1, immagine 3 di 3
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Alcatel OneTouch Elevate SIM Card Replacement: passo 2, immagine 1 di 3 Alcatel OneTouch Elevate SIM Card Replacement: passo 2, immagine 2 di 3 Alcatel OneTouch Elevate SIM Card Replacement: passo 2, immagine 3 di 3
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Alcatel OneTouch Elevate SIM Card Replacement, SIM card: passo 3, immagine 1 di 2 Alcatel OneTouch Elevate SIM Card Replacement, SIM card: passo 3, immagine 2 di 2
    • Locate the SIM card slot at the top left of the phone.
    • If an SIM card is not present, you can skip to step 4
  4. Alcatel OneTouch Elevate SIM Card Replacement: passo 4, immagine 1 di 1
    • The SIM card will have an indent at the top, use this to carefully pull the card from the slot.
  5. Alcatel OneTouch Elevate SIM Card Replacement: passo 5, immagine 1 di 2 Alcatel OneTouch Elevate SIM Card Replacement: passo 5, immagine 2 di 2
    • Grab the new SIM card making sure not to touch the metallic area.
    • With the metallic patch facing down, insert the card into the slot.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 460
